Error and empty deploy folder when running grunt for cascade story map.
213
11-23-2018 10:33 AM
SteveSedlock
Hello and Happy Thanksgiving here in the USA!
I am in the middle of deploying a cascade story map to a server.  I have been following the instructions in this article:  https://developerscorner.storymaps.arcgis.com/change-the-cascade-header-color-2ed0d5653a56
After completing the changes and updating index.html (which is toward the end of the above referenced document), I opened a command prompt in my working directory and ran grunt.  Runs along, but the following error occurs before completing the run:
Running "requirejs:builder" (requirejs) task
grunt[8564]: src\node_contextify.cc:628: Assertion `args[1]->IsString()' failed.
1: 00007FF71DBEECE5
2: 00007FF71DBC8196
3: 00007FF71DBC8261
4: 00007FF71DB9B56A
5: 00007FF71E3F2E52
6: 00007FF71E3F3FD8
7: 00007FF71E3F330D
8: 00007FF71E3F322B
9: 00000027E8ADC5C1
When I look at the deploy folder, all it contains is an empty app folder. No other files.
Any ideas?  Thanks!
Full text of command prompt window is below:
C:\Users\sedlo\Documents\GitHub\storymap-cascade>grunt
Running "jshint:nls-en" (jshint) task
>> 2 files lint free.
Running "jshint:nls-all" (jshint) task
>> 74 files lint free.
Running "eslint:target" (eslint) task
C:\Users\sedlo\Documents\GitHub\storymap-cascade\src\app\storymaps\tpl\print\media\Text.jsx
39:21 warning Dangerous property 'dangerouslySetInnerHTML' found react/no-danger
43:35 warning Dangerous property 'dangerouslySetInnerHTML' found react/no-danger
C:\Users\sedlo\Documents\GitHub\storymap-cascade\src\app\storymaps\tpl\print\PrintViewReact.jsx
258:20 warning Dangerous property 'dangerouslySetInnerHTML' found react/no-danger
✖ 3 problems (0 errors, 3 warnings)
Running "clean:build" (clean) task
>> 1 path cleaned.
Running "clean:deploy" (clean) task
>> 1 path cleaned.
Running "clean:jsapioptim" (clean) task
>> 0 paths cleaned.
Running "clean:fonts" (clean) task
>> 0 paths cleaned.
Running "mkdir:all" (mkdir) task
Creating "deploy/app"...OK
Creating "build"...OK
Running "copy:fonts" (copy) task
Copied 40 files
Running "copy:fonts2" (copy) task
Copied 9 files
Running "copy:fonts3" (copy) task
Copied 6 files
Running "copy:youtube" (copy) task
Copied 1 file
Running "copy:calcite-vars" (copy) task
Copied 2 files
Running "copy:less-in-react" (copy) task
Copied 116 files
Running "copy:hbs-in-react" (copy) task
Copied 63 files
Running "babel:dev" (babel) task
Running "copy:commonResources4react" (copy) task
Created 102 directories, copied 267 files
1: 00007FF71DBEECE5
2: 00007FF71DBC8196
3: 00007FF71DBC8261
4: 00007FF71DB9B56A
5: 00007FF71E3F2E52
6: 00007FF71E3F3FD8
7: 00007FF71E3F330D
8: 00007FF71E3F322B
9: 00000027E8ADC5C1
Returns to a command prompt.
TRDSYSTEMS
I'm also having this very issue. Was this matter ever resolved? if so, how were you able to resolve it?
OwenGeo
Esri Frequent Contributor
Please check to see if you are using a supported version of Node (v8). We've seen similar issues when trying to use Node v10. You can use nvm to swap to v8.
Owen Evans
