Colleagues are being asked for a login, even though all the data in my map is shared as public
934
8
06-14-2018 06:34 AM
SimonCrutchley
Occasional Contributor III
I've created a web app http://englishheritage.maps.arcgis.com/apps/StoryMapBasic/index.html?appid=19d82f2ca7514785aa315fcd5... which I've shared. It's based on a map http://englishheritage.maps.arcgis.com/home/item.html?id=befcdf7a2b2247c19419b769d8077ca4  which is also shared, but when my colleagues who don't have an ESRI account try to access it they are being asked to log in. What's going on?
StephenSylvia
Hi Simon, all the items are indeed public. I dug into your application configuration a bit more and it looks like the culprit is one of Feature Servers you configured to use in the map search tool. This feature service: https://services1.arcgis.com/GKHFS1tjFvm1DyXI/arcgis/rest/services/RRS_Reports_05_2018_WGS1984/Featu... (Research Reports (05/2018)) requires a token and is prompting the viewer to sign-in.
OwenGeo
Esri Notable Contributor
Hello Simon -- Sorry you are having difficultly with your story map. Can you please double-check the sharing on the web map? I can't access the web map item page via the link you provided above, so it seems that's not shared publicly.
Owen Evans
SimonCrutchley
Hi Owen,
As far as i can tell it is.
StephenSylvia
SimonCrutchley
Hi Stephen,
Thanks for that, but what do you mean by "requires a token"? I'm afraid I'm still quite a newbie. How do I change this?
StephenSylvia
When a service "Requires a token", it means it is private and requires a user to login. A token is just a type of web authentication method. When a user logs in with the credentials, the app will automatically generate a token to use to authenticate the service.
SimonCrutchley
Ah. so basically, that bit isn't shared? I'll share it and see what happens.
Ta
SimonCrutchley
Incidentally. you say you "dug down". is that relatively simple to do?
StephenSylvia
You can see the JSON behind your story or webmap using the AGO Assistant: https://developerscorner.storymaps.arcgis.com/editing-the-configuration-of-a-story-map-7b984560b7c2.
