I'm confused when adding content to my "Story Map Tour" or Story Map Journal. Are "Map Notes" the same as adding a layer and placing points on it? Also, when configuring the map for a Journal section, It just has a checkmark for "Map Notes" but does not let you differentiate between different sets of them.
Solved! Go to Solution.
Map notes are a type of layer that you can add to a web map through Map Viewer. It's helpful if you want to add couple of annotation. More information in the documentation at Map notes—ArcGIS Online Help | ArcGIS
If you add multiple layer you should be able to toggle them on and off in Map Journal
In Map Viewer
In Map Journal
In Map Viewer
In Map Journal
Thanks for your reply. Fast! I will study the links too.
Judie Piner
Preservation & Technology
Yavapai-Apache Nation
When in the map viewer, how do I add additional points to a map note at a later time?
You must have an edit button in the toolbar or use the option on the layer and click "Edit Layer"
