use webmap with custom WMS-service as a basemap
3182
8
06-04-2014 11:02 PM
RaivoAlla
New Contributor II
Hello!
I tried to use updated Map Tour template (downloadable version for developers), but have some complications.
The problem is that when I replace webmapid (in index.html) to b259b2e5e83a43eda8107f6017aaca09, then loading map tour it throws me an error: "Sorry, Map Tour loading failed"
My webmap http://maaamet.maps.arcgis.com/home/webmap/viewer.html?webmap=b259b2e5e83a43eda8107f6017aaca09
has custom WMS-service as a basemap (and with our national SRS EPSG:3301), so I guess this should be the problem?
I have no problem using it with some other webmap that has ESRI basemap.
I still assume, it should be possible to suck webmap with WMS-service as a basemap into storymap... but how?
Raivo Alla
Estonian Land Board
GregoryL_Azou
Occasional Contributor III
Hi Sorry about that.
It's quite weird I have it working on other WMS not in mercartor... I opened an issue on GitHub to track the bug.
From now, as a workaround, you can follow the developer guide and modify storymaps/core/Core.js loadWebMap function to set your extent in the correct projection.
GregoryL_Azou
It is possible to use a WMS basemap in any projection with Map Tour but I can think of a number of reason this may fail.
If you can share your webmap publicly, I can take a deeper look.
RaivoAlla
New Contributor II
GregoryL_Azou
Hi Raivo,
Your webmap doesn't seems public.
RaivoAlla
New Contributor II
Last one was AGOL for Organization map, indeed, this one is for public use  (last one was for "everyone" too, but in our organization):
http://www.arcgis.com/home/webmap/viewer.html?webmap=b259b2e5e83a43eda8107f6017aaca09
Points are loaded, but instead of basemap there is all white.
Raivo
RaivoAlla
New Contributor II
I mean, in the previous version of storymaps I could modify esri.arcgis.utils.createMap mapOptions (index.html) and simply add
extent: new esri.geometry.Extent({xmin:360000,ymin:6343000,xmax:730000,ymax:6657000,spatialReference:{wkid:3301}})
... to support EPSG:3301 SRS.
Now I cant find the place to do that.
Raivo
GregoryL_Azou
RaivoAlla
New Contributor II
Thanks!
I'll try it soon.
Raivo
RaivoAlla
New Contributor II
Well, no use setting our custom extent in the code (loadWebMap->arcgisUtils.createMap->mapOptions)...
Google Chrome console reveals that it still addresses GetMap request with SRS=4326.
Raivo
