Switching Basemap makes Pictures Disappear
679
03-08-2014 10:58 PM
TariqAlkharusi
Switching Basemaps in the Webmap resulted in the loss of all pictures saved in the story Map.
The Webmap contains all the pictures associated with Points. Is there a way to retrieve the Story Map or create a new one with all   the pictures?
Tariq.
GregoryL_Azou
Sorry for inconvenience. Your data should not be lost but your geometries are likely to be invalid.
What template are you using? How did you change the webmap, using ArcGIS.com viewer or the builder? Was there something specific to your data and basemap (different projection...). Are your picture stored in a Feature Service?
With more details I may be able to help more but from now your best hope is to try fixing your geometries using ArcGIS.com viewer by switching back to your previous basemap for example.
