StoryMap Journal help
4094
03-08-2015 09:20 AM
FerdinandQuinones
New Contributor II
I am building a StoryMap Journal. Most of my text to be input is in Word. When I try to paste the text into the Journal template, nothing happens.  Any tricks or suggestions to paste the text into the pages?  Thanks
RupertEssinger
Frequent Contributor II
Try using the keyboard shortcut for Paste: CTRL+V
It should work then
RupertEssinger
It should work then
FerdinandQuinones
New Contributor II
Hey Rupert, thanks a lot. Worked like a charm. Never too old to learn something new. Story Maps are great.
FerdinandQuinones
New Contributor II
Dear Rupert, another question about the Story Map Journal I am composing. How is the "Main Stage Actions" block activated? I would like to add some "pop-up" inserts into the main maps (either in the form of pictures or videos).  In the map journal I started it is not accesible (visible but not active). Any suggestions?  Thanks.
Cordially,
Ferdinand Quiñones
RupertEssinger
Select some text first in your journal section and those options should become enabled. They are only enabled if you have the text that you want to turn into a main stage action selected.
FerdinandQuinones
New Contributor II
Thanks again, Rupert.  I tested that and it works, but the size of the image inserted after selecting the text takes all the main page screen. Is it possible to reduce the inserts to pop-up size as I see on some of the examples?
