I have labeled a layer that I have added to my ArcGIS Online map for my story map. When I check the box to add labels, my Story map will not work and gives me the error message (see attachment)
thanks in advance for any help
Last night we released an update to the Shortlist that fixes the issue when the Shortlist web map contains layers that are labelled in ArcGIS Online. The Shortlist will display labels configured for any supporting layers in your web map (i.e. layers that don't define the tabs in your Shortlist. Labels for layers that define tabs are not displayed.
You can get the download from the Shortlist page on the Story Maps website, or via this link, or from the Story Map Shortlist Github repo.
Sorry you are having issues with the Shortlist. Can you share the web map ID with me to take a look? feel free to send privately if you do not want to share publicly.
Mark
Here you go, thanks Mark!
9961ade08c4849dba4218442e9b5d352
Strange, it loads properly on my test:
What browser are you on?
Do you have a link I can view?
The arc GIS online Map was updated on chrome and the main map was in Internet explorer...I think
Sent from my iPhone
Hi Mark, See my response to Katie below, also note that the map currently has the labels turned off so it works. Did you turn them on and it still works?
Thanks!!
No, I did not change anything. But looking at a web map with layers turned on, it does in fact trip up the code a bit, which is a bug. It should still be able to load, but the labels are ignored, as are any other styles applied to the point layers that make up the tabs. We will fix the bug and update the github repo and download.
Ok, thanks for the feedback, I will await your response so we can continue
Thanks again!
Wonderful, many thanks for all your efforts!
