Story Map Swipe: Issues with bookmark texts
2873
5
11-13-2014 08:03 AM
CONABIONC_for_Knowledge_and_Us
Dear all,
We noticed a funny issue in a storymap we´ve already published: http://speck.conabio.gob.mx/NALCMS/2005_2010/en/index.html
When you switch between the bookmarks you can see, that the text for each site is being cut, WHEN the title occupies more than one line!
Is this a bug or an error from us?
thank you and best regards,
Flo
P.S.: We found the following work-around. Define a ney css style, put the header you want to use within the main text, but in a own <p>paragraph</p> and apply the style you defined to this paragraph.
GregoryL_Azou
Regular Contributor II
Got it, thanks we will definitely fix that.
I opened an issue for you to track the bug being resolved Swipe series - long description are cut off · Issue #15 · Esri/swipe-map-storytelling-template-js · ...
GregoryL_Azou
Glad you found a workaround. I can't seem to reproduce in the link you gave or using the downloadable version without any modification. Is this title the issue? Maybe the issue only appear in some browser?
Hi Gregory,
seems that I didn´t explain well: What´s being cut is the end of the main text.
In the example below, for instance, the text is cut at the word "of", but there are some words (= one line) missing.
cheers,
Flo
GregoryL_Azou
Hi Gregory,
regarding the issues with the missing text line, we also noticed that neither text nor legend are shown correctly when you change the size of the browser window, e.g. when you make the window smaller and then maximize it again (see image below).
Another issue occurs when you make the window smaller and reload the map - in this case again the last line of the text is being cut.
I´m not sure if this is part of the bug you already reported?
cheers,
Flo
GregoryL_Azou
We will also look at that thanks
