Story Map Cascade marker and popups not working in Edge.
955
02-12-2020 09:54 AM
EmilySchad
Hi!
I'm new here and newish to web apps. We have a Storymap with markers that have popup functions that are not visible in Edge and in Safari the popup doesn't work. Has anyone else seen this? Here's the storymap:
http://fredericksburg.maps.arcgis.com/apps/Cascade/index.html?appid=309c4a01b6d048bb99df58249ffaf86f...
Can anyone give me any suggestions?
Thank you!
Emily
Tags (3)
EmilySchad
Okay, problem fixed. We republished it as a feature service and WFS and that fixed the issue. Thanks for all of your help.
Emily
EmilySchad
So I recreated a shorter version with just the maps and republished just so see if there was some new updates that needed to be included and the parking map markers are still not visible in Edge but are visible and interactive in Chrome. Also, odd is that the Planned Construction Projects in Downtown map works in Edge and the stars are interactive? Can anyone help?
I guess I'll republish the parking map service with maybe a different marker to see if that does anything.
Any help would be much appreciated! I can't imagine I'm the only one that has seen this issue?
Emily
EmilySchad
UPDATE: I tried republishing with a different style marking and it still doesn't work in Edge. When viewing the service in Edge the markers don't show up.
http://fredericksburg.maps.arcgis.com/home/webmap/viewer.html?useExisting=1&layers=c7b938ef96314fd49...
But I did notice the Downtown Contruction map that works in the same Story map was published as a FeatureServer whereas the Parking service is a map service? May this is the reason. I'll publish it as a FeatureServer to see if that works.
Downtown Construction:
https://fredericksburg.maps.arcgis.com/home/webmap/viewer.html?layers=c2c0bc60a5994b64a4a02a315ad37a...
Em
EmilySchad
Emily
