shortlist builder and enterprise
484
06-18-2018 05:41 AM
CrystalCowardin
I'm in the midst of creating some Story Maps with the Shortlist builder.  I just read that Shortlist will not be available in ArcGIS Enterprise.  We aren't using Enterprise yet but plan to in the future.  Will the story maps still work once we switch to Enterprise?  Should I be doing anything differently?  The shortlist builder is the best option for the type of story map I need.
Thanks.
RupertEssinger
Frequent Contributor II
Hi Crystal, we aren't currently planning to move Story Map Shortlist to ArcGIS Enterprise. Typically if you have publicly shared maps and apps that you have created in ArcGIS Online, which are being used by people outside your organization, you'd leave those in ArcGIS Online even if you move to ArcGIS Enterprise. Maps and apps in ArcGIS Online can access data served out to the public web by ArcGIS Enterprise.
Hope that helps.
Rupert
