search multiple sources
1990
01-19-2017 07:49 AM
MelissaPrindiville
I've added the search multiple sources code sample located https://developers.arcgis.com/javascript/3/jssamples/search_multiplesources.html.  however it doesn't appear to search the feature layer.  It does search the world geocode service but not the feature layer.  Any ideas on what I am missing.
I've added the District Feature Layer to the map and can see the Search box.
var sources = search.get("sources");
//Push the sources used to search, by default the ArcGIS Online World geocoder is included. In addition there is a feature layer of US congressional districts. The districts search is set up to find the "DISTRICTID". Also, a feature layer of senator information is set up to find based on the senator name.
sources.push({
featureLayer: new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/CongressionalDistricts/FeatureServ..."),
searchFields: ["DISTRICTID"],
displayField: "DISTRICTID",
exactMatch: false,
outFields: ["DISTRICTID", "NAME", "PARTY"],
name: "Congressional Districts",
placeholder: "3708",
maxResults: 6,
maxSuggestions: 6,
//Create an InfoTemplate and include three fields
infoTemplate: new InfoTemplate("Congressional District", "District ID: ${DISTRICTID}</br>Name: ${NAME}</br>Party Affiliation: ${PARTY}"),
enableSuggestions: true,
minCharacters: 0
//Set the sources above to the search widget
search.set("sources", sources);
search.startup();
-melissa
RupertEssinger
Esri Alum
Hi Melissa
Could you let us know which of the 8 Story Map apps you are customizing  ?
Rupert
MelissaPrindiville
Sorry the Shortlist storymap.
-Melissa
MarkCooney
Hi Melissa,
I think your code looks good, and should work.  This snippet worked for me:
define(["dojo/topic", "esri/dijit/Search", "esri/layers/FeatureLayer", "esri/InfoTemplate"], function(topic, Search, FeatureLayer, InfoTemplate) {
     * Custom Javascript to be executed while the application is initializing goes here
     // The application is ready
     topic.subscribe("tpl-ready", function(){
          * Custom Javascript to be executed when the application is ready goes here
          var search = new Search({
               map: app.map
          }, "search");
          sources.push({
               exactMatch: false,
               maxResults: 6,
               maxSuggestions: 6,
               minCharacters: 0
          search.startup();
