Replace a photo on the right side (Mainstage) of a section.
503
08-18-2021 04:00 PM
MerlinSmith
I can't change the photo on the right side of a journal story map. The only way I am able to replace the image is to copy the text, and create a new section with a new image.  There has got to be a better way.
OwenGeo
Esri Notable Contributor
@MerlinSmith -- There is no direct "replace" option available in classic story builders, but you should be able to easily insert the new image in the existing section and delete the old image (or delete the existing image first, then add the new one). You may need to separately delete the old image's caption, if there is one.
Is there a reason one of these workflow isn't working?
Owen Evans
OwenGeo
Owen Evans
