Problem with dynamic updates to shortlist story map
2965
11
01-16-2017 11:39 PM
BenParker
I'd like to be have my shortlist story map update dynamically when I add new points to the underlying feature service but I can't seem to get that to work. The web map shows the new points but the shortlist only shows the original ones.
Here are the steps I followed:
1. Created a CSV file defining my original set of locations for the story map.
2. Uploaded my CSV file to AGOL and used it to create a feature service.
3. Created a web map and used the feature service to create a layer.
4. Created a Shortlist story map from the web map.
5. Story map looks fine and all points present.
6. Updated my local copy of the CSV file to add some new locations.
7. User the "Overwrite" option on the feature service to upload the new CSV,
8. The feature service shows the new points.
9. The web map shows the new points.
10. The shortlist story map doesn't show the new points.
Not sure if it's a factor but my AGOL account is through the ArcGIS Home Use program.
Any advice appreciated. Thanks!
MarkCooney
Hi Ben,
You will want to double check the TAB_NAME field values, it appears the second tab that is showing up is because those features TAB_NAME field values have one more space than the other features.
Mark
BenParker
That was it. I removed all trailing spaces from the TAB_NAME entries in the CSV file and the duplicate tab is gone now. So with version 1.4.9 dynamic updates to the feature service are now properly reflected in the story map shortlist. Thanks for all the help in getting this working! You can consider this case closed now.
