Moving points in Story Map Tour
3315
8
05-15-2017 11:47 AM
MarkFleming
I'm finding in impossible to accurately locate a point in Story Map Tour. The little window says "Move me around or change my color. I can easily change the color but the point will not move.
Also when adding a new point, the location tab allows the input of decimal coordinates but only to three decimal places. For two points that are close together, this is not enough accuracy.
MarkFleming
Bingo; It is a browser issue!Chrome is the big loser. I can't move points on either tablet with the chrome browser.IE on the surface pro allows me to move points but not on the Xperia. Firefox
IE on the Surface Pro tablet allows me to move points, but not on the Xperia.
The only way to move points on the Xperia is with Firefox!
Complicated!
Thanks, Adrian
Mark
MarkFleming
Addendum; this inability to move points is with our tablets. We can move points with a desktop computer.
AdrianWelsh
MVP Honored Contributor
Mark,
I'm guessing this has to do with the tablet's mobile-based web browser. Which tablet and which browser are you using to try and move these points? I wonder if there is a way to 'force' the browser to act like a full-desktop-sized browser in order for you to have full functionality.
MarkFleming
Adrian;
I have two, a Sony Xperia and a Surface Pro 4.
Thank you
Mark
AdrianWelsh
Mark, which browsers are you using on your devices? Have you tried other browsers to see if they will behave properly?
MarkFleming
Complicated!
Thanks, Adrian
Mark
AdrianWelsh
All mobile browsers behave differently than their full-fledged counterparts. I am glad this was an "easy" fix.
EmilyLong
On desktop. Just tried moving points on Chrome, Firefox, Edge. None worked. But guess what does? Internet Explorer!  Really hope that's not ESRI's preferred browser....
RupertEssinger
Esri Alum
Hi Emily, you should be able to moving your Map Tour points around on any browser, not just IE
We do hear this occasionally about Map Tour and Shortlist and would like to track it down. It does seem to sometimes happen if you are signed in to an ArcGIS Organization in which the web maps use a Org level locator that references a missing data source, or references an HTTP data source in an HTTPS org. We'd recommend contacting Esri Support about the issue so they can help track it down.
Rupert
