Linking to a Specific Point in Tour Map that is Embedded in Series Map
1426
02-15-2017 01:28 PM
KevinHighland
Occasional Contributor II
Hi all,
I have an open ticket with Support regarding this, but wanted to throw it out here to see if anyone else already found a solution to it.
The situation is that I have a Series Map that has a tab that is a Tour Map. I was wondering if there is a URL parameter that will allow me to open a specific point in the Tour Map in the Series map. So the Series Map comes up, opens the tab with the Tour Map, and Tour Map goes to a specific point.
I was thinking it would be something along the lines of http://encinitas.maps.arcgis.com/apps/MapSeries/index.html?appid=abcb1e41a88e41f7b87aab875d988179&en... , but it is only taking me to the tab with the Tour Map.
Hopefully someone else has figured this out!
Kevin
RupertEssinger
Frequent Contributor II
Yeah, there's no way to make a URL that opens up the Story Map Series, goes to a particular tab in the Series, and then goes to a particular place in a Story Map Tour that is embedded in that tab.
You can of course embed a Story Map Tour in a tab in a Story Map Series so that it displays a particular place in that tour, using this URL (which includes &embed to make it headless like it is in your embed already)
https://encinitas.maps.arcgis.com/apps/MapTour/index.html?appid=63fc926eea204922905e567b3b60d7a5&emb...
The Story Map Series URL doesn't accept (and therefore ignores) the &index parameter you have added at the end of what you posted above.
Rupert
PS. I am based in San Diego County so I like all those City of Encinitas improvements going on
RupertEssinger
Rupert
KevinHighland
Thanks for the answer. I knew it was a longshot!
