Is there a way to make the symbols in the close up map the same as the symbols in the overview map?
2654
12-07-2015 12:38 PM
ChayaBalsiger
I created a story map using the countdown template.  I was wondering if there was a way to make the symbols in the close up map the same as the symbols in the overview map.  The overview map symbol has the rank number on the symbol:
Is it possible for the close up map to have the same symbol with the rank number?
LeeBock
Hi Chaya,
I think probably the easiest way for you to add those icons would be just to add them manually into your large scale webmap (during map authoring).  The large map will then show all the icons; however, the icons won't be as "active" as the icons in the overview map -- in other words they won't change color on selection or respond to mouseover etc.
If you really want to have both maps show the point datasets in equal manner, you'll have to modify the javascript code.  Unfortunately, the config doesn't support adding points to the large scale map.
Lee
LeeBock
Hi Chaya,
Lee
