Is it possible to create bookmarks in a Shortlist Storymap?
809
10-30-2017 12:53 PM
KevinBurkman1
I am creating a Shortlist Storymap that identifies particular historic sites in different regions (DC, Philadelphia, Boston etc.). I would like to be able to bookmark or pull down, that allows the user to select a particular region, then have it zoom to that area. Does anyone know if this is possible?
Thank you,
Kevin #ShortlistStorymap
OwenGeo
Esri Notable Contributor
Kevin -- Yep! You can enable bookmarks in Settings > Map options. Just create your bookmarks in the Shortlist web map and then check the box shown below. Optionally, you can change the name of the bookmark menu.
Then your bookmarks will appear in the Shortlist story like this:
Owen Evans
OwenGeo
Owen Evans
KevinBurkman1
Owen,
Thanks so much for replying so quickly.  Your advice is exactly what I was looking for!
Thanks again!
Kevin
