Is it possible to ad in storymaps an image with clickable areas as link to other pages?
842
10-30-2017 09:50 AM
LucZwartjes1
I would like to make a home storymap from where I open other storymaps. But for this case it would be best to link to the other storymaps from a clickable image, where on the image areas are selected as clickable.
Is this possible,
Luc
Tags (1)
OwenGeo
Esri Notable Contributor
Hi Luc -- Sure, you can do that, but you'll need to host your own web page that has the clickable image and then add that web page to your story map. There’s no customization of the story map required, and you’d just paste in the link to your custom web page to your home story map.
We did a clickable image a while ago in our thanksgiving story. There’s a bunch of generators available on the web, just google “Image map generator.” They will let you trace parts of an image and will then give you the html code. You can either make the clickable areas links to open a new page.
Owen Evans
OwenGeo
Owen Evans
