I am working on a research project surveying people using photos. I would like to embed the survey program (potentially Survey 123) into a Story Map format so that survey takers can be taken from one survey question to the next using a zoom out-zoom in mapping function. Would this be possible? I have not come across any examples of people using storymaps to provide surveys. The survey questions are place based.
Hi Dana,
I don't think it's possible to have a direct link between the survey and a storymap, but you could embed a Survey123 web form in a Map Journal side panel, have a web map in the main panel and use Story Map actions (Using Story Map Journal Story Actions | ArcGIS Blog) to direct the user to different locations in the survey.
I'm not sure it'd be possible to use the same survey over different sections/tabs.
Carmel
Hi Dana,
You could use Collaborate tab from https://survey123.arcgis.com. Esri has an option to integrate through HTML code. If you want to embebed into a StoryMap, you could copy and paste the code.
Other option is the URL, then you have it you must check the box "Open the survey directly in a browser".
I hope it will be useful.
Laura G.
