I need your help ....why can't I share post a story map on Facebook ....where all the sources and files are made PUBLIC and everything works just fine ?
1709
01-25-2018 06:26 PM
DanielBetts2
RupertEssinger
Esri Alum
Hi Daniel, I saw on another Geonet thread that you are posting this into Facebook and are getting an unexpected message back from Facebook when you do that. I can also reproduce that. Sorry about the issue
I'm not sure why that message is being returned in the default Facebook 'social card', and I've made a note of it with our team to see if anyone can explain it, or perhaps a Geonetter can explain it. I've not been able to reproduce that message with other story maps and I tried a bunch.
I think the story map is working fine and is shared publicly irrespective of what that message in the Facebook social card says. You can actually just close that errant social card by clicking the x control on it
and go head and do your Facebook post, adding any additional text or graphics that you want to include in the post. I just tried that in FB and it worked OK for me.
Rupert
OwenGeo
Esri Notable Contributor
Hi Daniel -- I can open and see your story map just fine. Did you fix the issue after posting your question or is there something else unexpected you see?
Owen Evans
RupertEssinger
Esri Alum
Rupert
DanielBetts2
Got it fixed ....just completely rebuilt a new one ....works like a charm
There seems to be quite a bit of variance in which CREATE button you use
....best results were to build from the Web Map app itself and not from the
Create Button on AGOL Content page
Thank you very much
RupertEssinger
Esri Alum
I just saw another example of this same issue with the Facebook preview when posting a Story Map Crowdsource. The story didn't have a thumbnail, and adding the thumbnail (via My Stories) seemed to fix the issue. I'm not sure if that explains the issue, but will report back if we can track it down.
Rupert
