How to download a map series builder app to further customize?
1858
01-30-2017 12:24 PM
AnnVanSlembrouck
I need to download a map created with the map series builder, in order to further customize.
It will remain on our web server as a hosted service.
Thanks!
OwenGeo
Esri Notable Contributor
Hi Ann,
If you download and host the application code for one of the story map apps that app still needs to point to either ArcGIS Online or an instance of Portal for ArcGIS to load the story configuration as well as any maps, scenes, or uploaded images that appear in the story.
You can run the builder from your own server to edit the story configuration stored on ArcGIS Online. The GitHub repository Saroj pointed to has all the information on how to deploy and configure the Map Series app.
Let me know if you still have additional questions.
Owen
Owen Evans
SarojThapa1
Ann,
 GitHub - Esri/map-series-storytelling-template-js: The Story Map Series lets you present a series of...
This esri github repository is well documented and can help you accomplish what you are trying to accomplish.
Good luck!
AnnVanSlembrouck
Thank Saroj, I was hoping to download all of the settings and customizations that were saved with AGO.
OwenGeo
Hi Ann,
Owen
Owen Evans
AnnVanSlembrouck
Got it - thanks! Very nice documentation.
Ann
