How do I remove the "a story map" font in the header of the countdown story map?
3132
12-03-2015 11:42 AM
ChayaBalsiger
I created a story map using the countdown template and I need to remove the words,"a story map" from the title, along with the facebook and twitter icons.  Is there a way to do this?
KyleBalke__GISP
My bad...for the Countdown Story Map take a look at the index.html.  There is a DIV named social that contains the information you want to remove.  Simply remove those line of code.  Starts on or near line 121 assuming you haven't made any other modifications.
KyleBalke__GISP
While in the builder mode go to Settings and then the Header tab.
ChayaBalsiger
I don't think you are looking at the countdown story map template as that is not how you create the countdown story map.  Thank you though.
KyleBalke__GISP
ChayaBalsiger
Thanks, that worked!
