How do I delete an image?
1756
12-19-2017 01:19 PM
by Anonymous User
Not applicable
I am starting my first Story Map and I am using the Cascade type.  I accidentally put a picture in the Title section that doesn't fit.  I can't delete it.  The only way I have found is if I delete the Title section, which I don't want to do because I have content in it.
Does anyone know how to delete an image in the Title?
OwenGeo
Esri Notable Contributor
Lesley -- There isn't an option to set a plain background in Cascade, so I would recommend you always add a background image. If you want to use a plain color image that can work, but you'll need to create and add your own colored graphic to achieve that effect. We are considering a feature that would let you set a background color, but we don't have a specific timeline on when that would be available.
Something else that might be helpful is to know that a Title section is independent of the sections that follow it, so deleting the title section won't delete anything else. Just insert a new Title section before the existing one, and then remove the old one.
Owen Evans
OwenGeo
Hi Lesley -- You can click the pencil icon in the lower left of the title section, then go to the Manage tab and then click Change Media to pick a new image.
Owen Evans
by Anonymous User
Not applicable
Hi, yes, thank you!  I did find that, but what if i want to remove the picture altogether and go back to it just being a plain background?  That is what I can't find.  Weird, right?
OwenGeo
Owen Evans
