Hi, I'm hoping to make a story map that uses lettered icons instead of numbers. The intent is to match a letter that P&Z department sends out. I changed the marker icons that appear on the map because I knew where the source for that was, as you can see in this photo [ATTACH=CONFIG]31464[/ATTACH]
The icons at the bottom, however, are still numbered and when I look at the html and JavaScript sources, I can't figure out what to change. Any help would be great!
