Help on story map customization
3100
11
06-15-2017 10:53 AM
NolwennLE_POULAIN
Hi everyone,
I'm trying to customize my story map and I'm meeting some troubles..
I've dowload the code on GitHub and I would like to put some legend on the images that are on the main stage
I've  tried this :
<script type="text/javascript">
require(["dojo/topic"], function(topic) {
* Custom Javascript to be executed while the application is initializing goes here
console.log("Map Journal is initializing");
// The application is ready
topic.subscribe("tpl-ready", function(){
* Custom Javascript to be executed when the application is ready goes here
topic.subscribe("story-load-section", function(index){
console.log("The section", index, "is being loaded");
var mainStageTitle = document.getElementById("mainStageTitle");
switch(index) {
case 0:
mainStageTitle.innerHTML = "South Resident Killer Whales, NL";
break;
case 1:
mainStageTitle.innerHTML = "Beluga, BC";
break;
default:
mainStageTitle.innerHTML = "Marine Mammals";
console.log("Map Journal is ready");
</script>
but anytime an error occured and say(index):340 Uncaught ReferenceError: require is not defined
I don't understant because I've follow some examples which were doing the same..
If someone could help me
Nolwenn
NolwennLE_POULAIN
Yes it was the exact same code!
You save me it works with surge!!
Ship Trafic Impact on Marine Mammals
I don't understand why it doesn't work on wamp but I will continue with surge it's much better!
Thanks a lot!!
NolwennLE_POULAIN
