Formatting text and paragraphs in a Map Tour
607
11-06-2018 09:37 AM
AllyLaidlaw
Hello!
When I'm trying to add a description of a tour point in a Map Tour, I want the description to be organized into short paragraphs. When I'm typing, I can see hard returns and indents in the text. However, after I'm done typing and I click out of editing mode, the hard returns disappear, and I'm left with an unsightly block of text. Is there any way to fix this?
Thanks!
Tags (3)
DanPatterson_Retired
RupertEssinger
Frequent Contributor II
In a Story Map Tour, you have to use HTML tags to specify formatting other than a single block of text. In this particular Story Map app, it doesn't accept returns when you enter text for the caption. Formatting is possible but only by adding HTML tags into your caption
Rupert
