I've tried adding two videos to a small Map Tour I've put together and not sure if i'm missing a configuration setting for the videos to run within full-size image frame, they currently keep popping in an additional window.
http://mceo.maps.arcgis.com/apps/MapTour/?appid=19c6389b1e1246dfb240db92406cb441
Map Tour points 1 and 3 have the videos...
Carl,
Here's a screenshot. Make sure you are chosing the "Video" option...If you leave "Picture" selected you'll see the "Picture Not Available" message if you add a video link.
Owen
Use this URL for the video you want to add. It has the URL parameter that prevents related videos from showing once the video ends. https://www.youtube.com/embed/D2Rw0SNr4io?rel=0
My settings does not show this, I used storing pics on AGOL
Carl -- Ah, ok -- unfortunately Map Tour doesn't currently support mixing videos and photos if you upload your photos to ArcGIS. If you want to use videos you'll need to find somewhere else to host your photos.
Owen
Thank you for that info.
