Does anyone have any experience of using a dynamic photo gallery as part of the main stage of story map?
540
06-08-2018 04:08 AM
LauraMalkin
Im using a Story Map Series - Tabbed version and would love to be able to have the main stage of a page showing a selection of images in a gallery form i.e. it carousels through the images.
I'm currently using an embedded flickr gallery but some where on the flick side it is adding a massive white border around the gallery and no editing of the iframe text corrects it.
See the 'Demolition' tab at https://hambletondc.maps.arcgis.com/apps/MapSeries/index.html?appid=ce1c9cfae7ac48b09d8a269180c387e2
Has anyone else managed to achieve anything similar successfully?
Any other ideas of free hosting sites as apposed to Flickr that have been successfully used?
TIA
OwenGeo
Esri Notable Contributor
Hi Laura -- The US Forest Service made a few stories (like this one and this one) where they used a JavaScript library called Slideshowify. You'd need to build the slideshow using that library, host the images and code on your own web server, and then embed the slideshow as a "web page" type media in your story map.
If you use Flickr to store your images, you can also try adding a Flickr gallery as described here.
Hope this is helpful.
Owen
Owen Evans
