Cascade Map (ArcGIS Server map images) - Health Report
861
02-09-2017 08:53 AM
BrianDudek
I am attempting to add features to the story map cascade with an ArcGIS Server map image link (Operations allowed->Map box checked only).  As I need to limit viewing of features to certain scales when made public.   However, the template is giving me Health Report errors when I add the map to the app and I get no information there.  I am not sure if it because it being recognized as a group layer or what?   I am adding it by a mapserver link as individual layers are not working.
Is there a way to get this working or is it a limitation of the Cascade beta?
EDIT:  Ok so it is recognizing the group layer after creating a new App template instead of the existing one I was using.    Not sure why.  All the layers are together though.  Now if I could only grab the individual layers MapServer/0 /1 /2, but it just says cannot be added to the map.
Thanks.
OwenGeo
Esri Notable Contributor
Hi Brian -- I'm not quite sure how things are being added in your story. Do you have a configurable app (like Basic Viewer) that you are embedding in Cascade or is the web map going directly into Cascade? Could you share a link to your story?
Owen
Owen Evans
