Hi friends,
My team is attempting to create a series of Story Map Tours in support of our organization, but is experiencing what appears to be a reproducible bug in the application configuration editor. It may be that we're using the tool incorrectly, but either way we'd appreciate any help &/or suggestions!
Steps to reproduce:
We can successfully create Story Maps using other Configurable Apps, e.g. Story Map Series & Story Map Journal, but the Story Map Tour fails every time.
Thanks in advance for your help!
Solved! Go to Solution.
Sorry about that, Map Tour builder seems to try to use one of the layer in your webmap as a source for the tour points. Is this what you are trying to do?
If not, please just change the visibility of all your webmap layers so they are not visible before you start the builder. After you will have saved your tour a first time, you will be able to turn back visible your layer.
Thanks, Gregory!
We are using a detailed map of one of our field sites that includes boundaries and features, but not the actual tour points, so we needed to use the visibility work-around you described.
That did the trick and I can safely say I would have never thought of that...
