Can you limit the map extent on a Story Map? (and add'l questions)
3149
01-28-2015 07:33 AM
ExploreMark_Twain_Lake
I have several questions on the Story Map ... working specifically with the Shortlist. The answers to some questions could alleviate the need for others. I'm just looking at different options, not necessarily to employ each of these features.
1) Can you limit how far the map pans out? So like, if someone was on a tablet, we wouldn't want them to swipe and end up in Europe?
2) Can you set a map focus for each tab, so that when the user clicks that tab it will adjust the map to include all of the locations within that tab?
3) Is there a way to make all of the locations remain in the left panel, even if their location is not shown on the current map?
Thanks so much for any help or suggestions!!
Mary
RupertEssinger
Frequent Contributor II
You can do those by customizing the code. The Story Map Shortlist doesn't support those via its configuration options.
