I do not see where to add a cover image to Story Map Tour Side Panel layout example as seen in the Palm Springs Map Tour. Can you please tell me where to add that?
Also, in adding a header logo the popup instructions say that the image must be a maximum is 250 x 50px. I assume that this is width and height like the Esri logo. But when I upload an image, it appears correctly in the preview box in the popup, but then the esri logo appears for the header when I click apply.
Thanks in advance for your help,
Alison
Oops - yes, I meant "apply"
It doesn't seem to be working for any of the logos we are trying to use. Here are the URLs we've tried:
