Discover how easy it is to create a database sequence for new features in your database using a calculation attribute rule and the NextSequenceValue Arcade function.
Am I the only one that the video doesn't show up for?
Hey Jeff can you view this ? https://www.youtube.com/watch?v=QPV_ydeoVY0
Yes. Thank you so much!
Thanks for sharing this video Hussein,
we plan to use immediate attribute rule and NextSequence function to automatically set the bylaw enforcement Case # field to auto-populate with the next Case #. Example, 21-00001 would be the first record in year 2021, 21-00002 will be second and so on until the year changes to the next on December 31 then we need to re-set the counter to zero and update the year. Example 22-00001 for first record in 2022. Do you have any suggestions how to implement that?
Thanks
@HusseinNasser2 This is great, thank you! One issue I have to if a feature is deleted, the sequence number still continues. For example, I create 2 features, and ID is populated as 1 and 2 respectively. If I delete feature 2, I would like the next feature to have ID 2 rather than ID 3. Any ideas how to approach this problem?
Hi
how NextSequence work with multiple versions SDE?
Am I correct in thinking that AGOL does not support NextSequenceValue?
