Transfer Values from Endpoint of line to connecting Point feature
1335
01-04-2021 06:41 AM
sjet1010
It would be nice to be able to set a calculation rule to pull data into a point layer from an upstream line layer. I want to pull the data from my upstream water / sanitary / and storm water lines and populate the downstream point layers. In attribute assistant you were able to do the to and from. Can you do that in attribute rule?
Scott_Harris
This video is not exactly what you are asking for, but it might be a starting point for getting there: https://www.youtube.com/watch?v=ueckrlhto0Q
Scott_Harris
sjet1010
Thank you. Do you know of a way to possibly stake mulitple intersects into one attribute rule? Example, if the line end gets moved to different point feature layer.
