Calculating number of characters in a field.
2185
09-21-2021 12:32 PM
V1212
Is it possible to calculate the number of characters in a field? I've tried using Count() but the expression doesn't work.
var lengthArray= [$feature.id]
if (count(lengthArray)!=10)
return false;
else return true;
Thanks in advance!
DavidPike
MVP Notable Contributor
Why are you creating a list/array? the count is always going to be 1.
var length = Count(Text($feature.id))
if (length != 10) {
  return false
else {
  return true
DavidPike
if (length != 10) {
  return false
else {
  return true
