Add option to the import tool, so that if a rule already exists it will be replaced. In many cases with updating multiple GDBs, a rule may exist already.
The create or replace is a common function for any Database tool.
This is a requirement when generating continual integration scenarios with pipeline build releases. Otherwise all rules must be dropped and re-added with each release.
It also assists when applying to a series of network stored geodatabases that may be different as they were created over time. Automation is the key to this request.
My workflow in these cases with automated GDB updates is to use a script to
