We have made the switch from GPS Correct to Positions, but cannot in any way shape or form get it to check in data. Been working with Trimble to try to get a solution, but I haven't been able to find anyone else who is successfully using it to see if we can figure out what is going on. We have upgraded to Win 7, have all drivers etc. up to date, are running Arc Basic 10.1, Arcpad 10, and are collecting data with a GeoXH. The error we get says that we can't chek in because the .axf file is in use by another process, even when there is nothing else running:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: The process cannot access the file 'S:\Gis\GeoXH Data\Check In\Sewer_2-25\KGID_Sewers_gps_mdb.axf' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite)
There is much more to the error message, but I am wondering if anyone else has fought through this?
Eric
