We have about 20 Juno SB units, in service for about 5 years. We've picked up 2 additional Juno 3B units to replace faulty units. They have been workhorses for us, but we do have a lot of the same issues others in this thread have experienced. We do a lot of wildlife surveys, so the accuracy has been acceptable (able to navigate and find a nest to repeat survey collection). The camera does not have the quality/zoom required, so we don't use them at all. We have had several units go bad, but over a 5 year period that is expected to a certain degree. We've had a couple units where the USB port has failed (motherboard replacement ~the cost of a new replacement unit, hence the 3B units). We have also had one just mysteriously fail to turn on, dead as a doornail- no tech support solution from vendor. And a smashed screen here or there, but usually the otterbox does it's job.
As far as performance issues, the most important advice I can give is avoid very large complex polygons! Do not create multi-part polygons. Land Ownership is a critical layer for us (to avoid trespass issues). The background matrix of contiguous private lands (this is not individual parcel data, just categorized public/private classes) can create huge, complex polygons that span across large sections of the state with tens of thousands of vertices, data holes, etc. We use an overlay tool to split the polygons to bite-size units, like PLSS townships. The other work-around is to clip your data to your project area to reduce the size of large or meandering features. Google "arcpad perfomance tips" to get other tricks, like turning off extensions, layers, simplify symbology, zoom-in tight as possible to study area for checkout, etc.
Found a lot of damn annoying bugs. Reported to esri, but they don't seem to get fixed. I.e. a definition query on a *date* field throws a serious error! Have to use a query on a dummy field instead. Minor workaround, but annoying as hell when you are trying to implement a clean, normalized geodatabase schema design across an organization. <grumble, grumble> Anyway, ...
Hope that helps. Good luck! Glad this thread was created. We're still a few years out from implementing Data Collector on Android, so I'll be browsing this discussion again.
--Jim
Hi all,
I have been using, recently, a Juno 5D. I got it because of the faster processor and beautiful display. I intended to use it either by itself, or as a data collector with my ProXH, thus replacing my Nomad. Here are the problems I have had:
a) cannot manipulate ArcPad with my fingers. I got some different types of styli, and found one from RadioShack ($20) with the smallest tip....it works....fairly well, but not really well. I took off the screen protector because I could not get the device to respond well with it on.
In the field the other day, during light showers, when the screen is damp/moist wet, I found that the touch screen is even less responsive.
But, the weirdest thing of all is that the device "lost" a few points that I was sure I had collected and saved. How can it do this? I never experienced this happening with an HP PDA, a Recon or a Nomad. It lost about 3 or 4 points our of 12 days work of maybe a couple dozen points. Nothing fancy in my data, not showing images, only a few background points and a simple 5 sided polygon for the site, only 44,000 sq m. How can it lose a few points out of a data set? If it was just one, or maybe two, then I would think that I messed up, what with the rain and attendant difficulties.
I went back to using my Nomad, I much prefer the positive response of the device to the hard stylus. For me, I don't think that the Juno 5D is truly a reliable or viable tool. I was in Saipan, a long way from home or a dealership, and lucky I brought a couple of redundant systems (Nomad/ProXH, two Garmins, etc).
