The ???meaning??? of ???V??? at the status bar of the ArcPad,
1762
01-12-2014 11:45 AM
JamalNUMAN
Legendary Contributor
I couldn???t figure out the meaning of the ???V??? available at the status bar of the ArcPad.
[ATTACH=CONFIG]30433[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
Tags (3)
HannahFerrier
Hi Jamal,
The far right of the Status Bar in ArcPad is used for 2 things:
1. Double-tap to display memory indicators. If there are 2 memory indicators, the icon with the green 'V' denotes the virtual memory. Double-tap a second time to dismiss the memory indicators.
[ATTACH=CONFIG]30478[/ATTACH]
2. The value in the Status Bar (V, H or Z) indicates the action button mode. This is for Windows Mobile devices that have a rocker button (+ and -) to navigate around your device. ArcPad allows you to use this hardware button to navigate around your map. By performing a press and hold on the rocker you can toggle through the following options:
Z mode: fixed zoom in/out
H mode: horizontal pan
V mode: vertical pan
Hope this helps,
Hannah 🙂
HannahFerrier
Hi Jamal,
Hope this helps,
Hannah 🙂
JamalNUMAN
Hi Jamal,
Hope this helps,
Hannah 🙂
Many thanks for the help. This is very useful.
Best
Jamal
Jamal Numan
