The best practice to add the multiple jpg images to ArcPad,
4311
09-25-2013 10:30 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
I�??m not sure about the best practice to add the jpg images to the ArcPad.
�?� If they are added directly from the ArcPad then :
o they are added one by one but not all in one go
o sounds that they are heavy in the ArcPad
[ATTACH=CONFIG]27755[/ATTACH]
�?� if they are saved as apm in the ArcMap then this will consume again massive size on the hard drive
[ATTACH=CONFIG]27756[/ATTACH]
then what might be the best practice?
Thank you
Best
Jamal
Tags (4)
PaulLohr
What are we talking about for image size (mb) and number of images?
You may need to use a different format and / or mosaic the images.
by Anonymous User
Not applicable
Thank you Paul for the help,
1. I have 19 images of 1.4GB
[ATTACH=CONFIG]27786[/ATTACH]
2. The format of my images is Jpeg
3. The images are already contained in mosaic but ArcPad doesn�??t read mosaic data
[ATTACH=CONFIG]27787[/ATTACH]
I think that the first step in any project is to add the satellite images to the ArcPad then one can start work!
There should be some way to add heavy images to ArcPad the same way we do in ArcGIS
Best
Jamal
KevinPrickett
Jamal,
I don't believe ArcPad has a function/tool to add a significant number of orthophotos at once, even if its just 19.  With little success, I have been working on adding several hundred images along a very long rail corridor into an ArcPad project. In ArcMap, I would utilize a raster catalog.  However, raster catalogs don't work in ArcPad (see Technical article http://support.esri.com/cn/knowledgebase/techarticles/detail/25934).  Here is one process used in exporting orthophotos to ArcPad (http://www.donmeltz.com/tag/arcpad/).
by Anonymous User
Not applicable
Jamal,
Many thanks Kevin for the help,
Exporting satellite images as .jpg includes resolution issue.
[ATTACH=CONFIG]29387[/ATTACH]
What might be the resolution that should be set for the jpg in order to preserve the same quality of the aerial photo has has 50 cm resolution?
[ATTACH=CONFIG]29385[/ATTACH], [ATTACH=CONFIG]29384[/ATTACH]
