Return Variable Function
2452
07-31-2013 02:15 PM
MitchDavis
Hey all thanks for your time!
I have this script created for auto incrementing my TREE_ID field in my table (TREE_ID = control). Long story short the script runs
from what i can tell and may even increment the first one but then stops. No errors either. The first point i put down starts with 2 but then it does not increment from there. Do i need to do anything with the strFieldName or intMax to make it work correctly?
Note: fairly new to working with script.
IF YOU SEE ANYTHING OUT OF PLACE LET ME KNOW! 😛
'InitializeForm
Sub InitializeForm
  Dim objEFControls, objEditForm
  Set objEditForm = ThisEvent.Object
  Set objEFControls = objEditForm.Pages("Page1").Controls
  If objEditForm.Mode = 3 Then
    Dim objTreeInitRS
    Set objTreeInitRS = Layer.Records
    objEFControls("TREE_ID").Value = ReturnNextID (objTreeInitRS, "TreeInit")
  End If
  Set objTreeInitRS = nothing
  Set objEFControls = nothing
  Set objEditForm = nothing
End Sub
'ReturnNextID
Function ReturnNextID (objRS, TREE_ID)
  Dim intMax
  objRS.MoveFirst
  intMax = 1
  Dim intCurrVal
  While Not objRS.EOF
    intCurrVal = Clng(objRS.Fields(TREE_ID).Value)
    If (intCurrVal > intMax) And (intCurrVal < 5000) Then
      intMax = intCurrVal
    End If
    objRS.MoveNext
  Wend
  ReturnNextID = intMax + 1
  Set intMax = nothing
  Set intCurrVal = nothing
End Function
Any help would be appreciated.
'supplement info Layer=TreeInit, Form= EditForm, Page= Page1, Control/field name = TREE_ID
Tags (3)
JamesMitchell
Did you manage to get this to work as i am having the same issue after upgraing to ArcPad 10.2.
