Recordset ToArray not working...
1806
03-29-2011 02:13 AM
SteveFitzgerald
According to the Arcpad Studio help file the Recordset object has a ToArray method.
An example is given using an AXF file.
I have successfully ran the example in a console window without problems.
When I try to use the ToArray method with a dbf file however, it gives me an "object doesn't support this action" error.
For example:
  Dim RS
  Set RS = Application.CreateAppObject("RecordSet")
  RS.Open "C:\Temp\Trees.dbf",1
  Console.print RS.RecordCount  'check recordset is open
  RS.ToArray 'error here
Any ideas anyone?
Steve
Tags (3)
SteveFitzgerald
It doesn't fix the problem but I should have assigned an array variable to the recordset ToArray method in the example above:
  Dim RS, anArray
  anArray = RS.ToArray 'error here
Any ideas anyone?
