No results for FindNearestXY?
799
02-04-2011 07:02 AM
PeterBold
I have a map with some polygone features in an AXF-Layer. I want to use the FindNearestXY-Method to get the record of the nearest polygon when I click into the map. Here is what I am doing:
Sub AddFeature
 Dim dblx, dbly
 dblX = Map.PointerX
 dblY = Map.PointerY
 If Not Map.SelectXY(dblx, dbly) Then
  If MsgBox ("There is nothing. Go on?", 4) = 7 Then
   Exit Sub
  Else
   Dim myRS
   Set myRS = Map.Layers("A").Records
   myRS.FindNearestXY dblx, dbly
   MsgBox myRSSite.FindNearestXY(dblx, dbly)
   Exit Sub
  End If
 End If
End Sub
The sub is called at the onpointerdown-event of the map-object. The FindNearestXY-Method dosen't cause an error, but it never finds a polygon. The result is always 0 - no matter where I click. Where is the mistake?
Thanks for your help.
Peter
Tags (3)
