that last post should work.
I just couldn't find a windows mobile version of GNSS internet radio.
the R8 with integrated Celluar board might do this a trick..
and justr set you minimum accuracy to .3m if you are chasing RTK fixed as a float is usualy around 700mm in your GPS preferences under quality.
From arcpad help about EPE
[INDENT]Maximum EPE
This field is used in the same way as the one described above.
When the second maximum check box is checked, a quality control is placed on the quality parameter selected. By default the Estimated Position Error (EPE) of incoming GPS positions is chosen for the second maximum value. The value in the box to the right specifies the maximum allowable EPE. The maximum allowable EPE you use should correspond directly to the maximum distance error you can accept. For example, if you can accept a maximum distance error of 15 meters, you should set the maximum allowable EPE to 15�??assuming your display units are set to metric on the Display tab of the ArcPad Options dialog box. EPE is only output by Garmin GPS receivers as part of a proprietary Garmin message, so this setting is only valid when using a Garmin GPS receiver.
This affects you in the following ways:
If the EPE of the current GPS position exceeds the maximum value while you are capturing a feature using the GPS, you will either get a warning message or not be allowed to capture data until the EPE is less than or equal to the maximum value, depending on whether Non-Compulsory Warnings or Compulsory Warnings is selected.
If the Maximum EPE Exceeded check box on the Alerts tab is checked, an alert message and/or sound occurs whenever the EPE of the current GPS position exceeds the specified value.
Other values that can chosen in place of PDOP are: HDOP, VDOP, TDOP, EPE, VPE, DAGE.
The default is unchecked and no value is specified.
[/INDENT]
