For ArcPad 10, using ArcPad on the Desktop to create new shapefiles, ArcStudio to tailor the fields in the shapefiles, and the "Get Data For ArcPad" wizard from the ArcPad Data Manager toolbar in ArcMap 10 to create a *.CAB file: After pulling the *.CAB file over to the GPS device (Magellan MM6) and installing the CAB file, the form dimensions (width&heigth), the number of and layout of the "PAGES" and the choices of "Controls" appearing for collected features in ArcPad do not match the pre-installed *.apl files for their respective shapefiles. The number of and order of the fields are correct. I'm looking for variables or settings leading to this result and could use suggestions. Im pulling the files from a file geodatabase and the coordinate systems of all files and map layer are consistent.
