Just came across this oldish post. Ran into this issue last year too. I found that if you loaded the combobox with a .dbf for your domain values it would limit results based on the user typing in the first few characters. No need to write code around all the events of the combo box changing or anything. Hope this helps if you haven't already found the answer.
Ryan
Ryan
