add XY event or import XY event into arcpad
1328
03-30-2011 07:29 AM
NathanEnge
has anybody done this or developed a tool button to do this?
Tags (3)
GarethWalters
Hi Nathan,
Yes you could do this with scripting. You could read, dbf, xml, csv etc. Using the Recordset object you can add a file and then scroll through the records and map eaxh one. Whether it be to a graphic or into a feature layer is up to you.
There is a sample called MultiNav that shows how to interact with XML data.
Hope this helps.
Cheers,
Gareth
GarethWalters
Hi Nathan,
Hope this helps.
Cheers,
Gareth
