Add limited number of features to related tables
4261
04-21-2016 12:25 AM
Nicole_Ueberschär
I got an ArcPad project file from our client which includes related tables. The related tables are loaded within the form when a new polygon is added.
Now I want to limit the number of features that can be added for this polygon. I thought of putting a loop on the "add" button, but I don't find a way to access or manipulate it.
Can anyone help me on this?
Besides: I found a spelling mistake in the Alias and the field name, when looking at the list view of the related table. Can I correct those somewhere? I can only access the caption at this point.
MarikaVertzonis
Regarding alias and field names - these come from the GDB - so the changes would need to be made there.
For limiting the number of features, you could create an onClick event for the OK button, and using a SQL query to determine how many related records you have on the feature, if it exceeds a given number, don't let the user proceed (or better still use the query to warn the user when they submit a related record that equals the maximum number).
Nicole_Ueberschär
Dear Marika,
Thanks for your comment.
The best would be that the plus button even disappears after the fourth crop was entered.
You also don't have an idea where I could access this plus button, do you?
MarikaVertzonis
I agree it would be ideal if you hide the plus button, but unfortunately that level of control in not available in the ArcPad object model.
