Access to other entires of a dbf table via vbs-script
1973
04-05-2013 12:32 AM
ValentinWittich
Hi there,
I'm trying to display further informations from a dbf-file after a user selected an entries from a combo box. Therefore I start the vbs-script over the onselok in the combo box.
<COMBOBOX name="SPECIES" x="32" y="22" width="94" height="100" defaultvalue="" listtable="species_list.dbf" listvaluefield="SPECIES" listtextfield="SPECIES" onselok="Call UpdateSpeciesList()" tooltip="" tabstop="true" border="true" sip="true" limittolist="false" sort="false" field="SPECIES"/>
In my vbs-File the function looks sofar like that:
Sub UpdateSpeciesList()
    Dim pForm  Set pForm = ThisEvent.Object.Parent
    pForm.Controls("SPECIES").ListIndex = pForm.Controls("NAME").ListIndex    '++ update other information         '++ something like Pages("page1").Fields("INFO").Value = xxx    Set pForm = Nothing  End Sub
For the moment the script just display the name of a species via the ListIndex in a second Combo field called NAME.
Now I want to display additional information from the same DBF entry. For example I have the text-field "INFO" where I want to insert the information form the row INFO. Any idea how I can realize that?
Regards Valentin
Tags (4)
ValentinWittich
Here my solution:
  UpdateInfo pForm.Controls("NAME").Value
  Set pForm = Nothing  End Sub  '++ insert infos from the table Sub UpdateInfo(output)
  Dim theControl, allControls, objInfo1, objDBF
  Set theControl = ThisEvent.Object
  Set allControls = theControl.Parent.Controls
  Set objInfo1 = allControls("objInfo1") ' name of the edit field
  ' load dbf file
  Set objDBF = CreateAppObject("recordset")
  objDBF.Open "\Storage Card\My Documents\Liste.dbf", 1 ' 1 = readonly
  ' move to the begining of the list  objDBF.MoveFirst
   'loop through DBF list until end of list
  For i=0 to objDBF.RecordCount-1
    If output=objDBF.Fields("NAME").Value then
    objInfo1.Value = objDBF.Fields("INFO").Value  ' INFO is the row we want to insert
    End If
    objDBF.MoveNext  'goto next record in DBF table
  objDBF.Close    'close DBF table
  ' clean up
  Set theControl = Nothing
  Set allControls = Nothing
  Set objInfo1 = Nothing
  Set objDBF = Nothing
End Sub
Don't hesitate to ask if you don't get what I did. I'm not sure if it is the cleanest way to solve the problem, but it works fine for me.
Regards Valentin
ValentinWittich
Here my solution:
  ' load dbf file
    End If
  ' clean up
End Sub
Regards Valentin
