I am following the code in this thread, but I am unable to write rasters to File GDB (have written GRID rasters successfully for years).I cannot get the nodata value to stick in the output raster (blank in properties) and the data values are reported as nodata when interrogating with the Identify tool in ArcMap. With GRID rasters, it was necessary to compute statistics on the raster before writing. Something is clearly wrong here because the code fails when computing statistics. If I skip that step then I get a garbage raster. Any ideas would be much appreciated!(All result code testing removed for brevity)HRESULT WriteGDBRasterTest(CString rasterParentDir,
CString rasterName,
CString& sDatatype,
int nCols, int nRows, double Xmin, double Ymin,
float pixWidth, float pixHeight,
float noDataValue,
float* rData)
AFX_MANAGE_STATE(AfxGetStaticModuleState());
HRESULT hr = S_OK;
CString sRaster = ExtractFileName(rasterName);
CString sWorkspaceDir = rasterParentDir;
long Width = nCols;
long Height = nRows;
double cellWidth = (double)pixWidth;
double cellHeight = (double)pixHeight;
double dXmin = (double)Xmin;
double dYmin = (double)Ymin;
double dXmax = dXmin + cellWidth*Width;
double dYmax = dYmin + cellHeight*Height;
IPointPtr ipPointOrigin(CLSID_Point);
ipPointOrigin->put_X(dXmin);
ipPointOrigin->put_Y(dYmin);
IPntPtr ipPntCellsize(CLSID_Pnt);
ipPntCellsize->put_X(cellWidth);
ipPntCellsize->put_Y(cellHeight);
IWorkspaceFactoryPtr ipWorkspaceFactory;
IWorkspacePtr ipWorkspace;
IRasterWorkspaceExPtr ipRasterWorkspaceEx;
hr = ipWorkspaceFactory.CreateInstance(CLSID_FileGDBWorkspaceFactory);
CComBSTR bWorkspaceDir = sWorkspaceDir.AllocSysString();
hr = ipWorkspaceFactory->OpenFromFile(bWorkspaceDir, 0, &ipWorkspace);
hr = ipWorkspace->QueryInterface(IID_IRasterWorkspaceEx, (void**)&ipRasterWorkspaceEx);
VARIANT_BOOL bPermanent = TRUE;
CComBSTR bsRaster = sRaster.AllocSysString();
IRasterDatasetPtr ipRasterDataset;
IRasterStorageDef3Ptr ipRasterStorageDef(CLSID_RasterStorageDef);
hr = ipRasterStorageDef->putref_CellSize(ipPntCellsize);
hr = ipRasterStorageDef->putref_Origin(ipPointOrigin);
CString ConfigKeyword = "";
CComBSTR bsConfigKeyword(ConfigKeyword);
IRasterDefPtr ipRasterDef(CLSID_RasterDef);
IGeometryDefPtr ipGeomDef = 0;
rstPixelType rasterPixelType = PT_FLOAT;
// Start with temp raster because need to use SaveAs to write raster correctly to FileGDB?
CComBSTR bsTempRaster = "temp";
hr = ipRasterWorkspaceEx->CreateRasterDataset(bsTempRaster, 1, rasterPixelType, ipRasterStorageDef,
bsConfigKeyword, ipRasterDef, ipGeomDef, &ipRasterDataset);
bsConfigKeyword.Empty();
ipRasterDef = 0;
ipRasterStorageDef = 0;
ipPntCellsize = 0;
ipPointOrigin = 0;
IRasterDataset3Ptr ipRasterDataset3(ipRasterDataset);
IRasterPtr ipRaster;
hr = ipRasterDataset3->CreateFullRaster(&ipRaster);
// If set props on raster then raster cursor works properly (but cannot set nodata)
IRasterPropsPtr ipRasterProps_fromRaster;
hr = ipRaster->QueryInterface(IID_IRasterProps, (void **) &ipRasterProps_fromRaster);
//// If set on dataset then raster cursor will NOT work (but can set nodata)
//IRasterPropsPtr ipRasterProps_fromDataset;
//IRasterBandPtr ipRasterBand;
//IRasterBandCollectionPtr ipRasterBandCollection;
//hr = ipRasterDataset->QueryInterface(IID_IRasterBandCollection, (void **)&ipRasterBandCollection);
//hr = ipRasterBandCollection->Item(0, &ipRasterBand);
//hr = ipRasterBand->QueryInterface(IID_IRasterProps, (void **) &ipRasterProps_fromDataset);
ipRasterProps_fromRaster->put_PixelType(rasterPixelType);
//ipRasterProps_fromDataset->put_PixelType(rasterPixelType);
IEnvelopePtr ipEnv(CLSID_Envelope);
ipEnv->PutCoords(dXmin, dYmin, dXmax, dYmax);
ipRasterProps_fromRaster->put_Extent(ipEnv);
ipRasterProps_fromRaster->put_Height((long)Height);
ipRasterProps_fromRaster->put_Width((long)Width);
CComVariant nodata(noDataValue);
//hr = ipRasterProps_fromDataset->put_NoDataValue(nodata);
hr = ipRasterProps_fromRaster->put_NoDataValue(nodata);
::VariantClear(&nodata);
// Why isn't nodata set in output layer????
//CComVariant nodata2;
//hr = ipRasterProps_fromDataset->get_NoDataValue(&nodata2);
//float test2 = nodata2.fltVal;
//VARTYPE vType = nodata2.vt; // This returns correctly {-9999., R4}
CComVariant nodata3((float)0); // Initializes vtype R4
hr = ipRasterProps_fromRaster->get_NoDataValue(&nodata3);
float test3 = nodata3.fltVal; // Comes back as safearray of R4, (with correct value in element 0)
VARTYPE vType3 = nodata3.vt; // 8196 = 0x2000 + 0x0004 (SafeArray + R4)
IRaster2Ptr ipRaster2(ipRaster);
IRasterCursorPtr ipRasterCursor;
hr = ipRaster2->CreateCursorEx(0, &ipRasterCursor); // Use default of full width x 128 rows
// Set up raster for writing
IRasterEditPtr ipRasterEdit(ipRaster2);
IPixelBlockPtr ipPixelBlock;
IPixelBlock3Ptr ipPixelBlock3;
long pixelBlockWidth = 0;
long pixelBlockHeight = 0;
IPntPtr ipTLC;
VARIANT_BOOL vNotFinished;
// Rotate through blocks using Raster Cursor
do {
hr = ipRasterCursor->get_PixelBlock(&ipPixelBlock);
hr = ipPixelBlock->QueryInterface(IID_IPixelBlock3, (void**)&ipPixelBlock3);
hr = ipPixelBlock3->get_Width(&pixelBlockWidth); // Should be same as ncols
hr = ipPixelBlock3->get_Height(&pixelBlockHeight); // Should be lesser of nrows and 128
hr = ipRasterCursor->get_TopLeft(&ipTLC);
double dTLRow;
hr = ipTLC->get_Y(&dTLRow);
int iTLRow = (int) dTLRow;
CComVariant varArray;
::VariantInit(&varArray);
hr = ipPixelBlock3->get_PixelDataByRef(0, &varArray); // Single band
SAFEARRAY *saArray = *(varArray.pparray);
hr = SafeArrayLock(saArray);
long long ij = 0;
long long lWidth = static_cast<long long>(Width);
for(int i = 0; i < pixelBlockHeight; i++) {
for(int j = 0; j < Width; j++) {
long ind[2];
ind[0]=j;
ind[1]=i;
ij = (i+iTLRow)*lWidth + j;
float val = rData[ij];
hr = ::SafeArrayPutElement(saArray, ind, (void*)&val);
hr = SafeArrayUnlock(saArray);
// Write out the new raster block
hr = ipRasterEdit->Write(ipTLC, ipPixelBlock);
hr = ipRasterEdit->Refresh();
// Advance the Raster Cursor
hr = ipRasterCursor->Next(&vNotFinished);
ipPixelBlock3 = 0;
ipPixelBlock = 0;
::VariantClear(&varArray);
} while (vNotFinished);
ipRasterCursor = 0;
ipRasterEdit = 0;
// New method to save to File GDB
ISaveAs2Ptr ipSaveAs(ipRaster2);
IDatasetPtr ipDS;
IWorkspacePtr ipWS(ipRasterWorkspaceEx);
hr = ipSaveAs->SaveAs(bsRaster, ipWS, CComBSTR("GDB"), &ipDS);
bsRaster.Empty();
ipDS = 0;
ipSaveAs = 0;
ipWS = 0;
//// Calculate RasterBand stats. MUST do to complete the band.(Was true for GRID anyway)
//hr = ipRasterBand->ComputeStatsAndHist(); // E_FAIL HERE (Also, NoData not getting set correctly)
//IRasterStatisticsPtr ipStats;
//hr = ipRasterBand->get_Statistics(&ipStats);
//double rMin, rMax;
//ipStats->get_Minimum(&rMin);
//ipStats->get_Maximum(&rMax);
//ipStats = 0;
// MUST release these pointers BEFORE creating and adding layer to map
ipRasterProps_fromRaster = 0;
//ipRasterProps_fromDataset = 0;
//ipRasterBand = 0;
//ipRasterBandCollection = 0;
ipRaster = 0;
ipRaster2 = 0;
ipRasterDataset = 0;
ipRasterDataset3 = 0;
ipRasterWorkspaceEx = 0;
ipWorkspace = 0;
// Must create new workspace and rasterdataset connections to get layer
bWorkspaceDir.Empty();
// Delete temp raster
hr = ipRasterWorkspaceEx->DeleteRasterDataset(bsTempRaster);
bsTempRaster.Empty();
// Open saved raster
IRasterDatasetPtr ipRDS;
CComBSTR bRName = sRaster.AllocSysString();
hr = ipRasterWorkspaceEx->OpenRasterDataset(bRName, &ipRDS);
bRName.Empty();
IRasterLayerPtr ipRasterLayer(CLSID_RasterLayer);
hr = ipRasterLayer->CreateFromDataset(ipRDS);
// Add Raster Layer to current map
IMapPtr ipMap;
hr = m_ipMxDoc->get_FocusMap(&ipMap);
hr = ipMap->AddLayer(ipRasterLayer);
// Refresh TOC
IActiveViewPtr ipActiveView;
hr = m_ipMxDoc->get_ActiveView(&ipActiveView);
hr = ipActiveView->Refresh();
hr = ipActiveView->ContentsChanged();
// MUST Release smart pointers
ipRasterLayer = 0;
ipActiveView = 0;
ipMap = 0;
ipWorkspace = 0;
ipWorkspaceFactory = 0;
ipRDS = 0;
return hr;
